MMARI.1
Senior II
May 20, 2023
stm32f7222ze clock configuration differ from datasheet and cube ide clock configuration
stm32f7222ze clock configuration differ from datasheet and cube ide clock configuration . stm32f7222ze datasheet clearly says APB2 - 108MHZ and APB1 -54MHz but cube ide clock configuration shows APB2 - 216MHZ APB1 -108MHz . which one should i follow .
AScha.3
what is "stm32f7222ze " ??
maybe stm32f722ze - then use the clock configuration you like , as long as nothing "in red " , warning : impossible clock .
if you dont need the high speed, take the lower and waste less energy.
