STM32CubeIDE vs Keil µVision generated code size
I used to generate code from STM32CubeMX then edit, compile and flash to board with Keil µVision (default config).
Recently, I followed bootloader tutorial that uses STM32CubeIDE and I must admit it's nice but for exact same source code, the generated code size in way bigger (47k vs 27k) and I need it to fit into 32k...
The Debug / Release configuration is unclear to me as well as compiler directive, isn't it technically possible to configure STM32CubeIDE to generate exact same code as Keil µVision from exact same source files ?
Hope someone can help :)
Have a good day,
Thomas
