Jackle
STM32CubeIDE levelX Code Generation bugs
Try to use LevelX customized Nor driver for STM32G0 in
lastest release STM32CubeIDE 1.14.1
When I regenerate code, whatever user code in lx_nor_driver_write() function will be copied to lx_nor_driver_block_erase() and lx_nor_driver_block_erased_verify().
static UINT lx_nor_driver_write(ULONG *flash_address, ULONG *source, ULONG words)
UINT ret = LX_SUCCESS;
/* USER CODE BEGIN NOR_WRITE */
=====> Whatever is here will go to lx_nor_driver_block_erase() and lx_nor_driver_block_erased_verify()
/* USER CODE END NOR_WRITE */
return ret;
static UINT lx_nor_driver_block_erase(ULONG block, ULONG erase_count)
=====>Whatever is here will go to lx_nor_driver_block_erase() and lx_nor_driver_block_erased_verify()
return ret;
static UINT lx_nor_driver_block_erased_verify(ULONG block)
return ret;
============= even when you delete user code section in lx_nor_driver_block_erase() and lx_nor_driver_block_erased_verify()
Regeneration will copythe user code in lx_nor_driver_write() to those two functions.
This is a serious bug and a stopper for user to use the software. Please have it fixed ASAP.
Ghofrane GSOURI
Hello @Jackle
First let me thank you for reporting.
I will check this issue internally and get back to you asap.
Thx
Ghofrane
