NJ_it
Mar 26, 2020 7:49 AM UTC
STM32CubeIDE has disabled external crystal selection for STM32F103C8 microcontroller.
I'm using version STM32CubeIDE 1.3.0 on Linux.
I am developing a USB application, so I will need to use the external crystal.
The external clock (HSE) for STM32F103C8 microcontroller is disabled in STM32CubeIDE. However, I see that it is possible to program with an external crystal (can be found in Figure 2. Clock tree of the datasheet).
Could someone please tell if I have done something wrong.
Steps to check is quite direct:
-> Select STM32F103C8Tx microcontroller.
-> In the .ioc file, "Clock Configuration", the HSE region will appear disabled.
Thanks.
TDKBest answer
Mar 26, 2020 1:07 PM UTC
Enable the HSE in Pinouts & Configuration --> System Core --> RCC --> High Speed Clock (HSE) --> ...
TDKBest answer
NJ_it
NJ_itAuthor
Mar 26, 2020 1:13 PM UTC
Thanks, I missed this initial step.
