STM32CubeIDE GDB Debug Port Clashed with Windows SearchApp.exe 62325
Hi
I had a problem where the GDB Server couldn't connect to the assigned port 62325.
Using Windows Sysinternals TCPView I ascertained that SearchApp.exe was using that port.
I changed back to the default port and all was well.
The question I have is there anything special about the defualt port number, or has it been arbitrarily set to the port region above 60000 as there don't seem to be any standard port definitions in this range?
Rob
