Ephraimoved
STM32CubeIde COMPILER
Dear Sir,
A project written for STM32U585 reaches the size 900 k bytes.
Trying to lower the size , I am tryin to use properties.
MCU GCC C compiler -> Optimization
Trying to set Optimization level to optimize most  to -Q3
the property of Optimization level is back to None (-Q0).
Please Advise.
    Hello @Ephraimoved
    Thank you for posting.
    Could you please provide the STM32 Cube IDE version.
    Thanks.
    Mahmoud.
    Ephraimoved
    Hi
    1.12.1
    MM..1
    Be care if you click on file yu change only one file optimize level. Click on project and try...
    And optimize is O not Q
    And when your previous optimize level is size, then O3 dont get you most super efect. You need optimize your code data system or replace MCU to 2M
    Perhaps you changed build configurations, or didn't hit Apply. This is a per-configuration setting.
