debugging
debuggingBest answer
Lead
Latest CubeMX is ok
AScha.3
Did you login to STM in the ide?
Now you have to...
But anyway, maybe better download new version of ide, than trying an update - my experience on Linux system.
And disable the " auto search for update" , on my system behaviour is better now.
Ghofrane GSOURI
Hello @debugging
First let me thank you for posting.
In order to update your STM32CubeIDE 1.15 , you need to check your connection by following those steps :
window-->Preferences --> type Proxy in filter
Choose Active Provider : Direct then click  Apply.
But there is an issue related to the update that has been detected in ticket 180624. For the moment, I advise you to download STM32CubeIDE 1.15.1 from this  LINK
THX
Ghofrane
debugging
debuggingAuthor
Lead
Thank you all.
AScha.3  Yes, logged in.
As stated, installed 1.15.1 fresh from the link, which needed to delete the .metadata  folder and  import all the projects). After that, even with direct setting (no proxy) still getting the error:  unable to read the repository.
P.S: Seen now others post from people with the same problem.
https://community.st.com/t5/other-software/can-t-connect-to-the-internet/td-p/673815
debugging
debuggingAuthor
Lead
changed to https:// and it started to "contacting sites...."
http://sw-center.st.com/stm32cubeide/updatesite1
Though still an error:
debugging
debuggingAuthorBest answer
Lead
Latest CubeMX is ok
