STM32Cube should generate clock defines
I want to know the configured core clock frequency at compile time, but unfortunately this value is not defined anywhere.
Thus I propose that the code generator should create a list of #defines for every node in the clock tree. I think SYSCLK, HCLK, APB1 and APB2 would suffice in most cases, but might as well #define all nodes.
Kind regards,
