JBonn
Stm32Cube IDE character spacing not consistent
Running STM32CubeIDE versions 1.18.1 and 1.19.0
i
static char *Audio3D[] = { // Main Settings display
"THERE ARE 15 VOLUME ",
IDE version 1.18.1 displays a 21 character line of code with the quotes one ontop of the other.
static char *Temp2D[] = {
" TEMPERATURE ",
" CELSIUS ",
" FAHRENHEIT "
IDE version 1.19.0 displays a 21 character line of code with the quotes not lined up
Makes it extremely hard to see if hundreds of lines of code are all 21 characters.
" TEMPERATURE ",
" CELSIUS ",
" FAHRENHEIT "
> quotes not lined up
Maybe a screenshot would be more descriptive here, yes?
Check that the file is pure UTF-8 characters and encoding is set correctly. Font is monospaced, should display the file contents accurately.
JBonn
JBonnAuthor
Please tell me How to set encoding. How to make fonts be monospaced.
unsigned_char_array
Lead III
Properties->Resource->Text File encoding (then set to UTF-8)
Preference->general->Appearance->Colors and Fonts->C/C++/Editor
Please format your code in your posts: https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
