STM32Cube IDE and versioning control with SVN
I'm a newbee in this community and my first post is related to an already existing one:
https://community.st.com/t5/stm32cubeide-mcus/stm32cubeide-with-svn-subversion-which-files-folders-to-ignore/td-p/253294
Usually we have \project\.settings\language.settings.xml under version control - but changes in this file seem to be not relevant to track it. Can you complete the answer referenced by the link above?
Best Regards,
Thomas
Hello  @ThoKu
Let me thank you for posting and welcome to the ST Community.
The file .settings\language.settings.xml is not required for building the project and may vary between PCs.
It is recommended to exclude the. Settings folder from SVN to avoid unnecessary conflicts.
Only project files like. project, .ioc, source code, drivers, and linker script should be version controlled.
Thanks.
Mahmoud
