STM32 cube examples?
So I have the STM32 CUBE suite - and I remember there is a means to select example projects to start from.
HOWEVER - I cannot find that any more :(
Mr Google tells me to do this:
Start STM32-CUBE, select FILE->NEW->OTHER->Create New STM32 Project
This does not provide me with ready made examples to choose from. These are very stripped down, not even hello world, just a main() with a endless for(;;) loop. With the default oscillator/clock.
I'm sure you have seen the BOARD selector, you select the chip, the board and you can pick examples
That is what I am looking for.  Where is that?
AScha.3
You looking for...this:
What version of : IDE , Cube , cpu     you use ?
Andrew Neil
You didn't say what version you're using.
Please see: How to write your question to maximize your chances to find a solution
From CubeIDE v2.0.0, Project creation & configuration is now handled only in the separate, standalone CubeMX.
The CubeMX functionality is no longer integrated in CubeIDE.
See: STM32CubeIDE 2.0.0 workflow tutorial
For the rationale behind it, and discussion of that, see: IDE Version 2.0.0 - why remove MX ?
