ngodoanvan
status return code in HAL Lib
Does STM HAL lib have a file which defined all return status code of system ?
    AScha.3
    AScha.3Best answer
    so - from ...def.h
    Hello @ngodoanvan ,
    If I understand correctly, perhaps you mean stm32h7xx_hal_def.h containing HAL common defines.
    AScha.3
    AScha.3Best answer
    so - from ...def.h
