MFawzy
static sack usage using command line
I know that the static stack usage is available in the stm32cubeide, but I'm wondering can I do it use a command line?
after more googling, I found that there is command for arm "armlink " that can run to get the stack used for each obj file ARM Compiler User Guide Version 6.6
but i couldn't find this command in stm32cubeide, , so what is the corresponding command in ST compiler?
Thanks,
Mohammed
waclawek.jan
CubeIDE uses the GNU suite around GCC, where linker is LD from the binutils project. AFAIK there is no static stack analysis built into these tools.
MFawzy
MFawzyAuthor
OK
MFawzy
MFawzyAuthor
I noticed that TI has a tool that can do it, and i wish if ST has the same
Software Development Organization (SDO) Applications Packages
waclawek.jan
You can post your request as an Idea here.
