Static library creation and impelementation to another empty project
I am currently working on user programmable project.
In my project, I want to make static library from all of my Middlewares, Drivers, Azure-RTOS, Include files, Source files, linker and startup. Therefore, I created new static library project in STM32CubeIDE and added all my files in it.
After this process, I did not do any extra changes for static library creation and hoped all linker and startup configurations are added to static library. I created static test project and added all my include files, static library and user code section. I changed linker path to the static library and i got some makefile errors right now. Working on it.
My questions are:
  1. Can I add my startup and linker files to static library like this? As you know that they are must for hardware and for compile process.
  2. How should I deal with makefile errors? I am a new developer for this area.
Thanks for your help!
Best Regards
B.KAYA
  • I learned how static library is created.
  • Created static library from my project with linker and startup.
  • Tested static library in empty project.
  • Got some problems with makefile.
Pavel A.
A static library is collection of object modules that are basically compiled C or C++ modules. It cannot contain linker files.
New developers are welcome to get practical help and advice, and learn!
https://www.upwork.com/services/search?q=stm32
https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot?ref=platform%3Astm32
https://www.fiverr.com/categories/programming-tech/online-coding-lessons
https://www.upwork.com/services/search?q=coding%2520lessons
