laurent_pubs
st-stm32cubeide_1.19.0-1.19.0-25607_20250703_0907 failed to install on fedora
I downloaded the STM32CUBE-IDE 1.19 for linux RPM today.
I use fedora43 on x86.
It failed to install:
sh-5.3# sudo /bin/sh
sh-5.3# ./st-stm32cubeide_1.19.0_25607_20250703_0907_amd64.rpm_bundle.sh
Creating directory makeself_dir_ZeOUue
Verifying archive integrity... 100% All good.
Uncompressing STM32CubeIDE installer 100%
grep: warning: stray \ before /
STMicroelectronics Software License Agreement
SLA0048 Rev4/March 2018
Please indicate your acceptance or NON-acceptance by selecting "I ACCEPT" or "I DO NOT ACCEPT" as indicated below in the me
dia.
BY INSTALLING COPYING, DOWNLOADING, ACCESSING OR OTHERWISE USING THIS SOFTWARE PACKAGE OR ANY PART THEREOF (AND THE RELATED
DOCUMENTATION) FROM STMICROELECTRONICS INTERNATIONAL N.V, SWISS BRANCH AND/OR ITS AFFILIATED COMPANIES (STMICROELECTRONICS
), THE RECIPIENT, ON BEHALF OF HIMSELF OR HERSELF, OR ON BEHALF OF ANY ENTITY BY WHICH SUCH RECIPIENT IS EMPLOYED AND/OR EN
GAGED AGREES TO BE BOUND BY THIS SOFTWARE PACKAGE LICENSE AGREEMENT.
Under STMicroelectronics' intellectual property rights and subject to applicable licensing terms for any third-party softwa
re incorporated in this software package and applicable Open Source Terms (as defined here below), the redistribution, repr
oduction and use in source and binary forms of the software package or any part thereof, with or without modification, are
permitted provided that the following conditions are met:
1. Redistribution of source code (modified or not) must retain any copyright notice, this list of conditions and the follow
ing disclaimer.
2. Redistributions in binary form, except as embedded into microcontroller or microprocessor device manufactured by or for
STMicroelectronics or a software update for such device, must reproduce the above copyright notice, this list of conditions
and the following disclaimer in the documentation and/or other materials provided with the distribution.
3. Neither the name of STMicroelectronics nor the names of other contributors to this software package may be used to endor
se or promote products derived from this software package or part thereof without specific written permission.
4. This software package or any part thereof, including modifications and/or derivative works of this software package, mus
t be used and execute solely and exclusively on or in combination with a microcontroller or a microprocessor devices manufa
ctured by or for STMicroelectronics.
5. No use, reproduction or redistribution of this software package partially or totally may be done in any manner that woul
d subject this software package to any Open Source Terms (as defined below).
6. Some portion of the software package may contain software subject to Open Source Terms (as defined below) applicable for
each such portion ("Open Source Software"), as further specified in the software package. Such Open Source Software is sup
plied under the applicable Open Source Terms and is not subject to the terms and conditions of license hereunder. "Open Sou
rce Terms" shall mean any open source license which requires as part of distribution of software that the source code of su
ch software is distributed therewith or otherwise made available, or open source license that substantially complies with t
he Open Source definition specified at www.opensource.org and any other comparable open source license such as for example
GNU General Public License (GPL), Eclipse Public License (EPL), Apache Software License, BSD license and MIT license.
7. This software package may also include third party software as expressly specified in the software package subject to sp
ecific license terms from such third parties. Such third party software is supplied under such specific license terms and i
s not subject to the terms and conditions of license hereunder. By installing copying, downloading, accessing or otherwise
using this software package, the recipient agrees to be bound by such license terms with regard to such third party softwar
e.
8. STMicroelectronics has no obligation to provide any maintenance, support or updates for the software package.
9. The software package is and will remain the exclusive property of STMicroelectronics and its licensors. The recipient wi
ll not take any action that jeopardizes STMicroelectronics and its licensors' proprietary rights or acquire any rights in t
he software package, except the limited rights specified hereunder.
10. The recipient shall comply with all applicable laws and regulations affecting the use of the software package or any pa
rt thereof including any applicable export control law or regulation.
11. Redistribution and use of this software package partially or any part thereof other than as permitted under this licens
e is void and will automatically terminate your rights under this license.
THIS SOFTWARE PACKAGE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS, IMPLIED OR STATUTORY WARR
ANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-
INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT
SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENT
IAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLU
DING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE PACKAGE, EVEN IF ADVISED OF THE POSSIBILIT
Y OF SUCH DAMAGE.
EXCEPT AS EXPRESSLY PERMITTED HEREUNDER AND SUBJECT TO THE APPLICABLE LICENSING TERMS FOR ANY THIRD-PARTY SOFTWARE INCORPOR
ATED IN THE SOFTWARE PACKAGE AND OPEN SOURCE TERMS AS APPLICABLE, NO LICENSE OR OTHER RIGHTS, WHETHER EXPRESS OR IMPLIED, A
RE GRANTED UNDER ANY PATENT OR OTHER INTELLECTUAL PROPERTY RIGHTS OF STMICROELECTRONICS OR ANY THIRD PARTY.
I ACCEPT (y) / I DO NOT ACCEPT (N) [N/y] y
License accepted.
Do you want to install Segger J-Link udev rules? [Y/n] n
Verifying... ################################# [100%]
Preparing... ################################# [100%]
package st-stlink-server-2.1.1-1.x86_64 is already installed
package st-stlink-udev-rules-1.0.3-2.x86_64 does not verify: no digest
Updating and loading repositories:
Repositories loaded.
Failed to resolve the transaction:
Problem: conflicting requests
- nothing provides st-stlink-udev-rules needed by st-stm32cubeide_1.19.0-1.19.0-25607_20250703_0907.x86_64 from @commandline
You can try to add to command line:
--skip-broken to skip uninstallable packages
Packages for argument 'st-stm32cubeide_1.19.0-1.19.0-25607_20250703_0907.x86_64' available, but not installed.
Nothing to do.
STM32CubeIDE installed successfully
sh-5.3#
laurent_pubs
laurent_pubsBest answer
 I managed to install the RPM version on Fedora.
The installer uses '/usr/sbin/rpm' and '/usr/sbin/yum'. 'rpm' needs the '--nodigest' (and --nosignature) options to ignore the issue. 'yum' need the --nogpgcheck option.
mv /usr/sbin/rpm /usr/sbin/rpm_orig
mv /usr/sbin/yum /usr/sbin/yum_orig
And create a wrapper for rpm and yum:
sh-5.3# cat /usr/sbin/yum
#!/bin/sh
/usr/sbin/yum_orig --nogpgcheck $@
sh-5.3# cat /usr/sbin/rpm
#!/bin/sh
/usr/sbin/rpm_orig -i --nosignature --nodigest $@
Then the installer ignores the digest issue and lets you install the tool.
Issamos
Hello @laurent_pubs
According to the RN0114, Supported operating systems and architectures
  • Windows® 10 and 11, 64 bits (x64)
  • Linux®: Ubuntu® LTS 22.04 and LTS 24.04, and Fedora® 41
  • macOS® 14 (Sonoma), macOS® 15 (Sequoia)
So, STM32CubeIDE V1.19.0 may not work with the fedora43.
Best Regards.
II
laurent_pubs
Fedora43 uses RPM6. RPM6 does not support CRC/MD5 signatures.
Could you generate RPMs with SHA-1 and SHA-256 signatures to comply with the latest RPM6 requirement?
Thank You.
Best Regards,
Laurent
Issamos
The Fedora 43 was released just days ago. So, I don’t think that it is compatible with the STM32CubeIDE V1.19.0. I think you should wait for the future releases of the STM32CubeIDE to ensure support for this Fedora version.
Best Regards.
II
Did you try the generic installer of CubeIDE?
This avoids problems with packet manager.
laurent_pubs
laurent_pubsAuthorBest answer
#!/bin/sh
#!/bin/sh
