split words
Hello i have an Arduino project. I need create an array of words from sentence:
char sText[] = "This is a long text.";
int x = 0;
String arr[5];
//split by space
char *token = strtok(sText, " ");
while (token != NULL) {
 arr[x] = token;
 x++;
 token = strtok(NULL, " ");
//new sentence > "This text"
char sNewText[] = arr[0] + " " + arr[4];
How can I do it similar in stm32CubeIde?
    Standard part of string.h surely?
    Would probably use strsep() as it's thread safe
    SchamannAuthor
    thx for your quickly reply, ofcourse i use string.h
    #include <string.h>
    but I have plenty of errors:
    String or string
    strsep or strtok does similar errors
    gui/src/encrypt_screen/EncryptView.cpp: In member function 'virtual void EncryptView::DoEncrypt()':
    gui/src/encrypt_screen/EncryptView.cpp:109:2: error: 'String' was not declared in this scope
    String arr[5]; //string arr[5];
    gui/src/encrypt_screen/EncryptView.cpp:109:2: note: suggested alternative: 'stdin'
    String arr[5];
    stdin
    gui/src/encrypt_screen/EncryptView.cpp:111:16: error: 'strsep' was not declared in this scope
    char *token = strsep(sText, " ");
    gui/src/encrypt_screen/EncryptView.cpp:111:16: note: suggested alternative: 'strset'
    strset
    gui/src/encrypt_screen/EncryptView.cpp:113:6: error: 'arr' was not declared in this scope
    arr[x] = token;
    gui/src/encrypt_screen/EncryptView.cpp:113:6: note: suggested alternative: 'VarOr'
    arr[x] = token;
    VarOr
    generated/simulator/gcc/Makefile:196: recipe for target 'build/MINGW32_NT-6.2/gui/src/encrypt_screen/EncryptView.o' failed
    make[2]: *** [build/MINGW32_NT-6.2/gui/src/encrypt_screen/EncryptView.o] Error 1
    make[1]: *** [generate_assets] Error 2
    generated/simulator/gcc/Makefile:155: recipe for target 'generate_assets' failed
    make: *** [all] Error 2
    simulator/gcc/Makefile:32: recipe for target 'all' failed
    Failed
