Set multiple UART interrupt in STM32G0B0
Now I'm implementing interrupt in USART1(PB7,PB6) and UART3(PC4,PC5).
So I wrote a USART1 code at first and It is working well.
However, I added a USART3 code and USART1 which is not working well even USART3.
I used this code.
USART_Communication_Rx_IT_Continuous_Init
Working well
void StartReception(void)
 /* Initializes Buffer swap mechanism :
 - 2 physical buffers aRXBufferA and aRXBufferB (RX_BUFFER_SIZE length)
 pBufferReadyForReception = aRXBufferA;
 pBufferReadyForUser = aRXBufferB;
 uwNbReceivedChars = 0;
 uwBufferReadyIndication = 0;
 /* Clear Overrun flag, in case characters have already been sent to USART */
 LL_USART_ClearFlag_ORE(USART1);
 /* Enable RXNE and Error interrupts */
 LL_USART_EnableIT_RXNE(USART1);
 LL_USART_EnableIT_ERROR(USART1);
After adding the USART3 code, it is not working
 USART3_pBufferReadyForReception = USART3_aRXBufferA;
 USART3_pBufferReadyForUser = USART3_aRXBufferB;
 USART3_uwNbReceivedChars = 0;
 USART3_uwBufferReadyIndication = 0;
 LL_USART_ClearFlag_ORE(USART3);
 LL_USART_EnableIT_RXNE(USART3);
 LL_USART_EnableIT_ERROR(USART3);
    Andrew Neil
    So does just the code for USART3 work on its own?
    You haven't shown any of your initialisation, nor your interrupt handlers.
    Yes, it did. USART1 and USART3 are working well separately.
    I put initialisation,  inetrrupt handler, callback code here.
    static void MX_USART1_UART_Init(void)
     /* USER CODE BEGIN USART1_Init 0 */
     /* USER CODE END USART1_Init 0 */
     LL_USART_InitTypeDef USART_InitStruct = {0};
     LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
     RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
     /** Initializes the peripherals clocks
     PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
     PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK1;
     if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
     Error_Handler();
     /* Peripheral clock enable */
     LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_USART1);
     LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOB);
     /**USART1 GPIO Configuration
     PB6 ------> USART1_TX
     PB7 ------> USART1_RX
     GPIO_InitStruct.Pin = LL_GPIO_PIN_6;
     GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
     GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_LOW;
     GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
     GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
     GPIO_InitStruct.Alternate = LL_GPIO_AF_0;
     LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
     GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
     /* USART1 interrupt Init */
     NVIC_SetPriority(USART1_IRQn, 0);
     NVIC_EnableIRQ(USART1_IRQn);
     /* USER CODE BEGIN USART1_Init 1 */
     /* USER CODE END USART1_Init 1 */
     USART_InitStruct.PrescalerValue = LL_USART_PRESCALER_DIV1;
     USART_InitStruct.BaudRate = 9600;
     USART_InitStruct.DataWidth = LL_USART_DATAWIDTH_8B;
     USART_InitStruct.StopBits = LL_USART_STOPBITS_1;
     USART_InitStruct.Parity = LL_USART_PARITY_NONE;
     USART_InitStruct.TransferDirection = LL_USART_DIRECTION_TX_RX;
     USART_InitStruct.HardwareFlowControl = LL_USART_HWCONTROL_NONE;
     USART_InitStruct.OverSampling = LL_USART_OVERSAMPLING_16;
     LL_USART_Init(USART1, &USART_InitStruct);
     LL_USART_SetTXFIFOThreshold(USART1, LL_USART_FIFOTHRESHOLD_1_8);
     LL_USART_SetRXFIFOThreshold(USART1, LL_USART_FIFOTHRESHOLD_1_8);
     LL_USART_DisableFIFO(USART1);
     LL_USART_ConfigAsyncMode(USART1);
     /* USER CODE BEGIN WKUPType USART1 */
     /* USER CODE END WKUPType USART1 */
     LL_USART_Enable(USART1);
     /* Polling USART1 initialisation */
     while((!(LL_USART_IsActiveFlag_TEACK(USART1))) || (!(LL_USART_IsActiveFlag_REACK(USART1))))
     /* USER CODE BEGIN USART1_Init 2 */
     /* USER CODE END USART1_Init 2 */
     * @brief USART3 Initialization Function
     * @PAram None
     * @retval None
    static void MX_USART3_UART_Init(void)
     /* USER CODE BEGIN USART3_Init 0 */
     /* USER CODE END USART3_Init 0 */
     PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART3;
     PeriphClkInit.Usart3ClockSelection = RCC_USART3CLKSOURCE_PCLK1;
     Error_Handler();
     LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_USART3);
     LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOC);
     /**USART3 GPIO Configuration
     PC4 ------> USART3_TX
     PC5 ------> USART3_RX
     GPIO_InitStruct.Pin = LL_GPIO_PIN_4;
     LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
     GPIO_InitStruct.Pin = LL_GPIO_PIN_5;
     /* USART3 interrupt Init */
     NVIC_SetPriority(USART3_4_5_6_LPUART1_IRQn, 0);
     NVIC_EnableIRQ(USART3_4_5_6_LPUART1_IRQn);
     /* USER CODE BEGIN USART3_Init 1 */
     /* USER CODE END USART3_Init 1 */
     LL_USART_Init(USART3, &USART_InitStruct);
     LL_USART_SetTXFIFOThreshold(USART3, LL_USART_FIFOTHRESHOLD_1_8);
     LL_USART_SetRXFIFOThreshold(USART3, LL_USART_FIFOTHRESHOLD_1_8);
     LL_USART_DisableFIFO(USART3);
     LL_USART_ConfigAsyncMode(USART3);
     /* USER CODE BEGIN WKUPType USART3 */
     /* USER CODE END WKUPType USART3 */
     LL_USART_Enable(USART3);
     /* Polling USART3 initialisation */
     while((!(LL_USART_IsActiveFlag_TEACK(USART3))) || (!(LL_USART_IsActiveFlag_REACK(USART3))))
     /* USER CODE BEGIN USART3_Init 2 */
     /* USER CODE END USART3_Init 2 */
    void USART1_IRQHandler(void)
     /* USER CODE BEGIN USART1_IRQn 0 */
    	if (LL_USART_IsActiveFlag_RXNE(USART1) && LL_USART_IsEnabledIT_RXNE(USART1))
    	/* RXNE flag will be cleared by reading of RDR register (done in call) */
    	/* Call function in charge of handling Character reception */
    		USART_CharReception_Callback();
    	else
    	/* Call Error function */
     /* USER CODE END USART1_IRQn 0 */
     /* USER CODE BEGIN USART1_IRQn 1 */
     /* USER CODE END USART1_IRQn 1 */
     * @brief This function handles USART3, USART4, USART5, USART6, LPUART1 globlal Interrupts (combined with EXTI 28).
    void USART3_4_5_6_LPUART1_IRQHandler(void)
     /* USER CODE BEGIN USART3_4_5_6_LPUART1_IRQn 0 */
    	if (LL_USART_IsActiveFlag_RXNE(USART3) && LL_USART_IsEnabledIT_RXNE(USART3))
    		USART3_CharReception_Callback();
    	else
     /* USER CODE END USART3_4_5_6_LPUART1_IRQn 0 */
     /* USER CODE BEGIN USART3_4_5_6_LPUART1_IRQn 1 */
     /* USER CODE END USART3_4_5_6_LPUART1_IRQn 1 */
    void USART_CharReception_Callback(void) {
    	uint8_t *ptemp;
    	/* Read Received character. RXNE flag is cleared by reading of RDR register */
    	pBufferReadyForReception[uwNbReceivedChars++] = LL_USART_ReceiveData8(
    			USART1);
    	/* Checks if Buffer full indication has been set */
    	if (uwNbReceivedChars >= RX_BUFFER_SIZE) {
    		/* Set Buffer swap indication */
    		uwBufferReadyIndication = 1;
    		/* Swap buffers for next bytes to be received */
    		ptemp = pBufferReadyForUser;
    		pBufferReadyForUser = pBufferReadyForReception;
    		pBufferReadyForReception = ptemp;
    void USART3_CharReception_Callback(void) {
    	uint8_t *ptemp;
    	USART3_pBufferReadyForReception[USART3_uwNbReceivedChars++] = LL_USART_ReceiveData8(
    			USART3);
    	if (USART3_uwNbReceivedChars >= RX_BUFFER_SIZE) {
    		USART3_uwBufferReadyIndication = 1;
    		ptemp = USART3_pBufferReadyForUser;
    		USART3_pBufferReadyForUser = USART3_pBufferReadyForReception;
    		USART3_pBufferReadyForReception = ptemp;
