chriskuku
Senior II
SEMIhosting doesn't work (ST-LINK OpenOCD)
I'm trying to get semihosting to work under STM32CubeIDE with ST-LINK(OpenOCD) debugging.
After being able to connect to the target (an STM32H503), I cannot step over the function initialise_monitor_handles()  (see source code). A lot of traps occur but I can't get into the real code to debug. (the lines in the main.c while loop).
Bear with me but the code looks a bit like swiss cheese. Tried various reads, scanf etc. But at the moment I cannot get across the "initialise_monitor_handles();" call.
Without reading everything I noticed you renamed syscalls.c to syscalls.c.disabled.
This makes your functions like _read() and _write() NOT to overwrite the default weak functions.
Is this intended?
chriskuku
chriskukuAuthor
Senior II
I was following the KB article here and there is says in 2.1:
2.1. Remove default syscalls.c
Remove default <syscalls.c> file from build if this file is included in STM32CubeIDE project.
which I devotely did.
Andrew Neil
Does it work if you don't try to step over it?
chriskuku
chriskukuAuthor
Senior II
No. It vanishes in the call.
But I found that I forgot to put
mon arm semihosting enable
With this in the startup I can step over until the loop in which I want to read a line of input. This read now works exctly once.
Open On-Chip Debugger 0.12.0+dev-00623-g0ba753ca7 (2025-04-30-14:20) [https://github.com/STMicroelectronics/OpenOCD]
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.org/doc/doxygen/bugs.html
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : STLINK V2J46M33 (API v2) VID:PID 0483:374B
Info : Target voltage: 3.223529
Info : Unable to match requested speed 8000 kHz, using 4000 kHz
Info : clock speed 4000 kHz
Info : stlink_dap_op_connect(connect)
Info : SWD DPIDR 0x6ba02477
Info : [STM32H503CBTx.ap0] Examination succeed
Info : [STM32H503CBTx.cpu] Cortex-M33 r0p4 processor detected
Info : [STM32H503CBTx.cpu] target has 8 breakpoints, 4 watchpoints
STM32H503CBTx.cpu in Non-Secure state
STM32H503CBTx TrustZone disabled
STM32H503CBTx.cpu work-area address is set to 0x20000000
STM32H503CBTx.cpu work-area is enabled
Info : [STM32H503CBTx.cpu] Examination succeed
Info : gdb port disabled
Info : starting gdb server for STM32H503CBTx.cpu on 3333
Info : Listening on port 3333 for gdb connections
Info : accepting 'gdb' connection on tcp/3333
[STM32H503CBTx.cpu] halted due to undefined, current mode: Handler HardFault
xPSR: 0x21000003 pc: 0x080007b8 msp: 0x20007fa0
Info : device idcode = 0x10036474 (STM32H50xx - Rev Y : 0x1003)
Info : Product State = 0xED : 'Open'
Info : flash size = 128kbytes
Info : flash mode : dual-bank
Info : New GDB Connection: 1, Target STM32H503CBTx.cpu, state: halted
undefined debug reason 8 (UNDEFINED) - target needs reset
Info : New GDB Connection: 2, Target STM32H503CBTx.cpu, state: halted
xPSR: 0x21000003 pc: 0x080007b8 msp: 0x20007fa0, semihosting
Info : Padding image section 0 at 0x08002e44 with 12 bytes (bank write end alignment)
xPSR: 0x61000003 pc: 0x2000005a msp: 0x200000d0, semihosting
1 Enter string:
helo
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (8295 ms). Workaround: increase "set remotetimeout" in GDB
5 Received char: helo
read-select 1
The next printf("%d Enter string:\n",i) is not executed, as it seems.
chriskuku
chriskukuAuthor
Senior II
At the moment I cannot find the most recent post, where I got advised to use OpenOCD options:
-c "gdb_report_data_abort enable" -c "init" -c "arm semihosting enable" -c "arm semihosting_fileio enable"
and ended up in:
Info : Target voltage: 3.225098
semihosting is enabled
semihosting fileio is enabled
Error: The 'gdb_report_data_abort' command must be used before 'init'.
