RTOS Aware Debug
IDE VERSION: v1.14.1+
Target: STM32H750
Debugger: ST-Link
So, 98.9% of the time I try to enable RTOS aware while debugging using the ST-Link I receive this message:
After that, I'm no longer able to debug code. This is normally "worked around" by closing the IDE and trying again, but as you can imagine, it is not a viable solution.
I have no clue what is going on, so if you need details, please share what you might need captured.
rmartinsAuthor
I should also add that this is for FreeRTOS.
Hello @rmartins
Could you try with the latest version of STM32CubeIDE v1.18.0.
KR,
Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
