Protobuf
Is there a possibility to use protobuf format. If possible can you please explain the process how to pack the protobuf format in the board.
Iam using STM32H573I-DK Board
    mƎALLEm
    mƎALLEmBest answer
    This has no relation with the board nor even with the STM32.
    It's something you need to implement by software:
    https://protobuf.dev/getting-started/cpptutorial/
    Github: https://github.com/protocolbuffers/protobuf/tree/main/examples
    mƎALLEm
    mƎALLEmBest answer
    Pavel A.
    Here you can get help with adding 3rd party software to your STM32 project.
    https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot
