Matth1
Proper way to code in C++, as IOC tool won't update main.cpp but rather create a new main.c
Hey everyone,
I'm trying to make a project in C++. I tried the trick to rename main.c to main.cpp with the right-click > rename function. It works, but then if I change the IOC with the config tool, it will create a new main.c with the proper settings (and ignore main.cpp).
What would be the proper way to use C++? Is there a setting to have main.cpp updated in case of a config change ?
Cartu38 OpenDev
Cartu38 OpenDevBest answer
Graduate II
May 12, 2022
Pavel A.
May 12, 2022
The proper way to use C++ with CubeIDE is just three simple steps:
  1. Put all your C++ code in your own files (and name the cpp files so that base name differs from any C file created by Cube. Thus, no "main.cpp" - choose a different base name).
  2. Leave all C files created by Cube as is, and let them be compiled in C mode,
  3. Call your C++ "main" from the main.c
If you want to use a different IDE, please say so.
Matth1
Matth1Author
Thanks. Actually I now know my problem was with header files for C++ where I didn't properly added
#ifdef __cplusplus
before C++ code (e.g. extern "C", including C++ libraries, ...) . So the compiler not knowing it was supposed to be C++ showed an error.
I think I now managed to do the "bridge" between C and C++, and that is what most users do: leave main in C and from there call my C++ call that is in other files.
Cartu38 OpenDev
Graduate II
May 12, 2022
Matth1
Matth1Author
Thanks!
