Project imported from TouchGFX but not able to debug for board STM32H745I - DISCO
@Semer CHERNI
plz help with this problem.
Board : STM32H745I - DISCO
Cubeide : v.1.13.2
TouchGFX : v4.22.1 Designer
STM32H745I - DISCO as it is dual core m4 and m7
1st i did build and debugging for m4 processor. It is successful.
2nly done with building for m7 processor.It is successful
But while debugging the m7 i am facing following issue ??????
Semer CHERNI
Semer CHERNIBest answer
First let me thank you for posting.
Could you please share the debug configuration for both project with the Debugger and Startup view.
KR,
Semer.
Semer CHERNI
KR,
Semer.
Thanks sir
I found one of the solution in which external loader setting was done.
i did the same and issue is solved
Hi Chaitanya,
Is it possible to point me to the solution? I am facing this same issue now as well.
Regards,
Reuben Goh
