AMaci.16
Project creation failure
I got this error message when trying to create a new stm32 project. Culd you help with this?
Markus GIRDLAND
Markus GIRDLANDBest answer
I think it's because you have a space in your name. We have a ticket for this, I believe you can do the following as a workaround:
  1. Exit STM32CubeIDE
  2. Go into the installation directory (C:/ST/STM32CubeIDE_1.0.0/STM32CubeIDE by default) and edit the stm32cubeide.ini file
  3. Add this line at the end of the .ini file: -Djava.io.tmpdir=C:/ST/tmp
  4. Create the tmp folder in the C:/ST directory
  5. Start CubeIDE and try to create a project
Markus GIRDLAND
AMaci.16
AMaci.16Author
Thank you Markus, that solved the problem.
regards,
Alberto Macias E.
