Senior III
Project building but not uploading to board
I have a project that builds with no errors but when I "Run as..." the project builds but  never enters the upload sequence so doesn't upload.
The board in question is a Nucleo F411RE & is communicating fine over UART. A previously loaded project is still sending out its debug messages, so I know the USB is good.
Debug is not playing either...
mƎALLEm
mƎALLEmBest answer
Check your debug settings in Startup tab:
mƎALLEm
mƎALLEmBest answer
Senior III
Thanks of the reply, I just switched the project to Cube 2.xx & everything's fine now
mƎALLEm
Good. So please mark the solution.
