program Make not found in PATH
Hello Everyone,
got an error when i build my project error :- Program "make" not found in PATH
i cross check properties and i put the address where all makes are located.
despite Screenshot (22).pngof doing this get the same error when build the project
    Hello @Smit Italiya ,
    It seems that your Path is not correct.
    Check your installation path of CubeIDE.
    Imen
    Hello @Imen.D
     I checked my installation path and it is correct, i have another question., is it possible if my toolchain is different from arm gnu in this case can i get the same error ? "makefile not found in path"
    Pavel A.
    Did make (build) ever work since you've installed CubeIDE?
    Did it work before installation of the Paragon plugins?
    MKing
    in my case i had to "generate code" again in an empty folder by CubeMX to solve the problem.
    I use STM32CubeIDE 1.14.
    When everything is correct it shows in the console output widow:
    11:12:56 **** Incremental Build of configuration Debug for project ****
    make -j8 all
    When i had the problem it shows in the console output widow:
    make all
