Streamer
Problem in Release Mode
I am using the STM32F302R8Tx microcontroller. I usually work in debug mode. One day, I decided to use release mode and faced a problem. I looked for a solution and then tried several methods sequentially.
1)I had tried optimizasyon
2)include my driver layer
I didn't get result.  Can you help for this problem?
I didn’t get any false evaluation in Debug mode
D:/Work/PLM/ST/STM32CubeIDE_1.19.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.13.3.rel1.win32_1.0.0.202411081344/tools/bin/../lib/gcc/arm-none-eabi/13.3.1/../../../../arm-none-eabi/bin/ld.exe: cannot find D:stm32BuildDriverMyDriverInc: No such file or directory
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:63: BuildDriver.elf] Error 1
Radosław
Mydriver  folder isn't marked as souce folder.
Notice this folder icon looks different to SRC folder
Project setting -> C/C++ general -> Path and symbols  -> goto Source folder tab  add your folder
AScha.3
Simple solution: dont use "release mode" !
Detailed ...: "debug" and "release" are just names for two group of settings;
- you can set same settings in both, then no difference - and useless to use both;
- you can set different settings, maybe have different optimizer setting, etc. , but then you get different code.
So up to user (you) , to use it not at all, or if you do: know, what you doing and why.
Why i never use it : i want to be 100% sure, the program i make and debug is exactly whats running then permanently .
Radosław
This is vary bad advice.  Debug and release have different purposes, very importat for proper software development.
AScha.3
@Radosław
So please explain: what different settings you use and why is it useful for "proper" software development.
