Problem building I3C for STM32H7R7 in Cube IDE, need help.
I just started to look into this chip for a new project, so I decided to try to build a sample program in the Cube IDE. It seemed to work until I tried to enable I3C. Now the build system is complaining about missing files. The missing file is 'stm32h7rsxx_util_i3c.h', the error is '.../Drivers/STM32H7RSxx_HAL_Driver/Src/stm32h7rsxx_util_i3c.c':20:10: fatal error: stm32h7rsxx_util_i3c.h: No such file or directory'. Where can I find this file and where do I put it? Any help is appreciated, thanks.
Hello @danr ,
I was able to reproduce your request.
Thank you for bringing this issue to our attention.
An internal Ticket was submitted to the Development Team (Internal Ticket Number: 216212).
I will keep you up to date when the problem is solved.
Thanks.
Mahmoud
danrAuthor
I was able to fix this, I found a copy of the file somewhere on my HDD and was able to copy it into '.../Drivers/Inc/'. Then I was able to build it.
mbarg.1
Senior III
I guess you are following a wrong approach.
Take full advantage of the STM32CubeIde - post your design, describe step by step what you did - MUST work unelss:
  • You did an error - you did not use the tool as it was intended - we will find that and teach you ( and other) not to do these errors;
  • There is an error in the tool - we will lobby to get fisxed and nobody will waste time in future with this problem.
Thank you
Mike
Hello @danr ,
Let me thank you for posting and welcome to the ST Community.
For more investigation, could you please provide your Ioc.File.
Thanks.
Mahmoud
Hello @danr ,
Thanks.
Mahmoud
