JKut
Post-generation hook in STM32CubeIDE
In our workflow around the code generation and building firmware using STM32CubeIDE, we have certain manual steps after code generation.
Is there a place to hook in a script to be run after code generation completes? Similar to the "Build Steps" which can be configured in Eclipse CDT projects?
Pavel A.
May 28, 2022
Just use the Pre-build step?
JKut
JKutAuthor
Yeah I'm aware of that option, but "just" using it isn't that simple. Code generation happens in the order of "once in a while", while building is done in the order of "always".
Our post-generation steps are rather lengthy, and also can't be repeated. E.g. applying patches shouldn't be repeated.
Pavel A.
May 28, 2022
In the script, check if the post-generation is already done, then skip the lengthy things.
JKut
JKutAuthor
So how do you suppose to do that in a general case, if you don't know nothing about whether and when code generation has happened or not? By the timestamp of a known generated file? Is there a specific candidate file you would have in mind?
