Senior
Post build steps
Is it possible to make the command line and description for pre-build and post-build steps larger? It’s a nightmare working with them as they are.
I know you can call a script file, but it would still be nice to see more than just a single line.
Hello ​@MA4
The Pre-build and Post-build steps fields are inherited from Eclipse CDT build settings UI, and those text areas are typically fixed-size or only minimally resizable depending on the perspective/layout.
Thanks,
KR, Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
