KK Y.1
PDM2PCM library
I am planning to convert PDM samples received from MP34DT05TR-A to PCM samples with 24 bit resolution at 48KHz sampling frequency using PDM2PCM library in stm32f401RE MCU. As per document PDM2PCM library only gives samples with 16 bit resolution and 16KHz sampling frequency. Is there any way to get PCM samples with my required specification(24 bit 48KHz sampling frequency)
