cjaya.1
on the STM32CubeIDE, once I initailize the necessary devices on .ioc, does it required to generatate the code automatically. once I enable a device, it always generate the code. I have to restart the whole code again from scratch.
Once I generate it. It deletes all the code work I have done.How can I disable that happening.
Pavel A.
Pavel A.Best answer
October 10, 2022
First and foremost, use some method to save your work and recover when needed: git or other version control. Or just make a copy of everything.
Next, check the options in the "project manager" group. There is option to NOT delete all files before re-generation. Learn about the USER CODE guard blocks.
Pavel A.
Pavel A.Best answer
October 10, 2022
cjaya.1
cjaya.1Author
Thank you for the reply. Does this "Code generation" is required in order to the device to work for example USART2 interrupts initialization and work with the interrupts receive.
Pavel A.
October 11, 2022
The code generation is not strictly required. For example, you can write it yourself :)
