New.Fish
Old AC6 Project fails on TruStudio and STM32CubeIDE
We have a more than 10 years old STM32F100 project which was built by AC6, I try to use TruStudio and STM32CubeIDE 1.6.1 to import , and build it, but all fails on Error "Program "make" not found in path".
How to fix it?
    mƎALLEm
    mƎALLEmBest answer
    Did you follow the steps described in the UM2609 / 2.1.3 Importing existing projects?
    Andrew Neil
    @New.Fish wrote:
    STM32CubeIDE 1.6.1
    Is that a typo? The current version is 1.16.0
    If you just use STM32CubeIDE to create a brand new project from scratch - does that work?
    mƎALLEm
    Did you try the steps described in the UM2609 importing projects, especially the section 2.1.3 Importing existing projects:
    New.Fish
    New.FishAuthor
    Hi SofLit,
    It prompt some warning message during converting, refer to attached image file.
    Finally, the compiler pass to  build it now,  but it generate a log message, refer to the text file,
    will this affect the debugging?
    mƎALLEm
    mƎALLEmBest answer
