NUCLEO-L4P5ZG in STM32CubeIDE, wrong defaults for QSPI
STM32CubeIDE offers creating a new project by selecting the board the NUCLEO-L4P5ZG. But the defaults e.g. for the QSOI as documented in the Nucleo-144 manual does not fit with the default in CubeIDE.
Pinout&Configuration->Connectivity->QSPI->Data[3:0]
The port, which is documented for the nucleo-144 can't be selected
That needs to be adapted manually int the pin configuration itself. That's weird, if you can't even select the correct port in the octospi configuration itself.
