Ax111_
May 17, 2022 9:39 AM UTC
No st link connected
I have st-link v2 with Firmware version V2J39S7.
I have been trying to debug through STM32 cube ide but it says " NO ST-LINK DETECTED".
I have also tried via Cube programmer and updated the stlink but still of no use. Have done the boot thing too.0693W00000Nq5d4QAB.pngCould anyone say whats possibly going wrong.
Andrew Neil
May 17, 2022 9:43 AM UTC
Try to think where you last saw it ...
Andrew Neil
May 17, 2022 10:06 AM UTC
Is it connected to the Host computer?
Does the Status LED light correctly on the ST-Link?
What computer is it - Windows? Mac? Linux? a VM? other ... ?
Does the PC detect it; eg, on Windows:
Ax111_
Ax111_Author
May 17, 2022 10:08 AM UTC
hello, i am using windows and it is being detected under Universal serial like you mentioned in your picture
Andrew Neil
May 17, 2022 10:21 AM UTC
See below - check your ST-Link Serial Number in the debug configuration ...
Andrew Neil
May 17, 2022 10:09 AM UTC
It seems to be looking for an ST-Link with the Serial Number 'U':
0693W00000Nq5koQAB.pngThat's not a valid serial number - check your debug configuration!
Ax111_
Ax111_Author
May 17, 2022 10:25 AM UTC
i have tried with the SN number of ST link and everytime it shows me this:0693W00000Nq5pAQAR.png
Andrew Neil
May 17, 2022 10:33 AM UTC
It's telling you that the ST-Link is stuck in Upgrade mode:
ie, it started doing an upgrade, but it failed.
What happens if you hit 'Open in update mode' again?
This is probably best done in the Cube Programmer - rather than trying to do it from the IDE while it's trying to start a debug session ...
BTW, the IDE Serial Number ("SN", or "S/N") setting is here:
0693W00000Nq5rGQAR.pngjust uncheck the box if you don't need to specify a particular ST-Link.
Amel NASRI
May 17, 2022 12:57 PM UTC
Hi @Ax111_​ ,
Several hints are provided in the article How to solve debugger connection issues?
Keep us informed. If problem is resolved, please precise which hint helped you.
-Amel
Ax111_
Ax111_Author
May 18, 2022 9:08 AM UTC
yeah, sure.
KWOOJ
Oct 14, 2022 4:56 AM UTC
I am also in the same situation.
Is your problem solved?
If so, how did you solve the problem?
I have several STlinks, and as a result of testing, the new stlink I bought shows the same problem as you, but there was no problem with the old STlink.
Ax111_
Ax111_Author
Nov 23, 2022 7:31 AM UTC
Hello, I didnot find any. so I thought of buying a nucleo Board instead
