No editor descriptor for id org.eclipse.ui.internal.emptyEditorTab
Hello @sovik32 ,
Which version of CubeIDE are your using? Make sure to update STM32CubeIDE to use the latest version.
Maybe you have a workspace cache issue. So, try start STM32CubeIDE with the -clean option to clear the cache.
Make sure to have the required plugin :
  • Go to Help > About STM32CubeIDE > Installation Details and ensure the correct plugins are installed.
  • If the plugin is missing, reinstall it via Help > Eclipse Marketplace or Help > Install New Software.
Otherwise, reinstall STM32CubeIDE to restore the default plugins.
Hope this helps you!
