My CubeIDE is broken
   My CubeIDE 1.18.0 was working fine for many weeks with Nucleo-H753ZI board and CubeMX.
   Two days ago, it stopped working after I upgraded it to version 1.19.0. The screen stayed in IDE home window.
  Then
  1, I deleted directories below
      C:\ST\STM32CubeIDE_1.19.0
       C:\Users\User\STM32CubeIDE
       C:\Users\User\.eclipse
       C:\STM32\Workspace
   2, I Installed STM32CubeIDE 1.18.0 as administrator.
   However, the project can't be built. I found -
  1. Window → Preferences → C/C++ → Build → Environment list is empty.
  2. .C:\Users\User\.eclipse is missing.- was not regenerated.
   I repeated the above steps to install 1.19.0 as administrator. The result is the same.
  2. .C:\Users\User\.eclipse is missing.- was not generated.
Thank you very much for your help,
Rong
AScha.3
AScha.3Best answer
you could try :
 >>  To fix this, just remove this file inside your workspace:
 >>  .metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
 >>  Hope this solves the issue.
 >>  (this file is the responsible of saving your workbench layout)
Then start IDE and see...and tell.
btw I run V 1.18.1 , is "best" so far.
AScha.3
AScha.3Best answer
you could try :
    Please read my last message - I deleted the workspace before my IDE installation.
The problem is
    No project can be built.
    Thanks,
Rong
