snigg
Multiline selection not visible after MacOS 26.2 update
It seems that after I updated MacOS to Tahoe 26.2 the IDE does not show selected text if over multiples lines correctly. This is a nightmare to work with, as it does not show selected text and can make you delete (overwrite) lines while editing.
Anyone else? Is there a setting to fix it?
Ghofrane GSOURI
Hello @snigg
Thank you for posting.
A ticket has been escalated to dev team regarding this issue.
Internal ticket ID is 224479 and it will be fixed as soon as possible.
THX
Ghofrane
snigg
sniggAuthor
Any update on this? I have seen with the ticket ID this already has been raised last year. It is very annoying to use the IDE this way.
Ghofrane GSOURI
Hello @snigg
Yes, I agree with you that this issue is very annoying. However, macOS 12.6.2 was published on December 12, 2025
(link: https://developer.apple.com/news/releases/?id=12122025c).
STM32CubeIDE 2.0.0 was released on November 18, 2025, and the ticket was escalated on 2025-12-30. We are doing our best to correct this behavior as soon as possible.
THX
Ghofrane
snigg
sniggAuthor
Its been more than a week and there is still no update. What is the timeline?!
snigg
sniggAuthor
ST, please take down the note you support MacOS and or set STM32CubeIDE to legacy status. You seemed to have invested in a Visual Code Studio integration of the STM32 stuff, so is this now the way to go? Could you at the very least be transparent in your strategy?!
Arete
Explorer
Same issue here, please provide update.  Frustrating to say the least.
It is really annoying - frustrating.
I also filed a ticket. Lets hope they will fix it. Or otherwise I'll buy other microcontroller from a different manufacturer.
VSCode does not have the nicer debug facility.
It is probably related to eclipse framework which had to adopt to some changes in macos. https://github.com/omnetpp/omnetpp/issues/1479. Maybe releasing new version based on newer eclipse fix the problem.
callsignhermit
For the record, this was finally fixed in the 2.2.0 update.
