SDu T
MQTT Nx_iperf
Good day
Has anyone integrated MQTT on the STM32H563ZIT?
I managed to get the Nx_iperf running on my custom board, but I need some help on integrating MQTT into this.
I have never used Azure RTOS and any help would be appreciated
    Guillaume K
    Hi
    There is an MQTT example for STM32H573I-DK in Cube H5 under Projects\STM32H573I-DK\Applications\NetXDuo\Nx_MQTT_Client. It also uses TLS.
    You have to adapt it to STM32H563ZIT (nucleo board ?).
    SDu T
    SDu TAuthor
    Hi
    I tried that example. But as it is, before i try to make it work on my board, I cannot get it to compile.
    I downloaded it via Github as well as the .zip file from the ST site. I import is as I would normally but I just cannot get it to compile. I am currenly using STM32Cube IDE V1.15.0
