Sellyette
May I convert KEIL MDK-ARM to STM32CubeIDE?
Hi, I have some problem. anyone help me.
I am not expert with STM32.
I bought a STEVAL-D35R16B. it is RFID EVAULATION BOARD.
I want use it. I downloaded demo firmware files.
but I can not open it with STM32CubeIDE.
Because it is for KEIL MDK-ARM.
May I convert it to STM32CubeIDE?
please help me..
The downloaded software is following link (ST.COM)
https://www.st.com/en/embedded-software/stsw-st25r018.html
    RhSilicon
    Lead
    August 11, 2023
    Hi, perhaps an alternative is the MBED. I found a document saying that the MBED project can be imported into Keil, check if there is a way to import the Keil project into MBED.
    https://os.mbed.com/
    This application note shows how to import mbedOS projects directly into uVision IDE provided by MDK.
    https://www.keil.com/appnotes/files/an282.pdf
    There isn't an importer specifically for a KEIL project inside STM32CubeIDE (such as with SW4STM32 or TrueSTUDIO). However, you might still be able to manually import a project by gradually moving source code from one project to the other and resolving any issues that arises.
    https://community.st.com/t5/stm32cubeide-mcu/is-there-any-way-to-convert-a-keil-project-into-a-stm32cube/td-p/185074
    Pavel A.
    August 11, 2023
    Here you can find help with porting your project to CubeIDE.
    And also with creating any small test/example code to your order.
    August 11, 2023
    STEVAL-D35R16B ??  You mean STEVAL-25R3916B
    Perhaps download a demo of KEIL-MDK so you can build and understand the construction of the project.
    Yes, ST needs to do a better job at providing this using CubeIDE, and importing projects from Keil and IAR
