alessandro.breuza
Jan 29, 2026 7:31 AM UTC
Live Expressions font size
how may I change font size for Live Expressions view?
None of the options in General | Appearance | Colors and Fonts has effect.
Alessandro
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Jan 29, 2026 8:50 AM UTC
Hello @alessandro.breuza
Let’s try changing the global display scale at the operating system level so that all text, including the Live Expressions view, appears larger.
Example (Windows 10 / 11):
Right‑click on the Desktop and select “Display settings”.
In the “Scale & layout” section, under “Scale”, choose 125% or 150%.
Apply the change, then restart STM32CubeIDE so it picks up the new scaling.
THX
Ghofrane
Ghofrane GSOURI
Jan 29, 2026 8:02 AM UTC
Can you please confirm whether you already tried the following steps?
From the menu: Window → Preferences
Navigate to:
General → Appearance → Colors and Fonts → Debug
Change one or more of these: The detail pane text font ,Modules view details..
Select the entry → click Edit… → choose the new size and font → Apply and Close.
If Live Expressions doesn’t pick it up immediately, try closing and reopening the Live Expressions view, or restarting STM32CubeIDE.
I will be waiting for your feedback.
THX
Ghofrane
alessandro.breuza
Jan 29, 2026 8:20 AM UTC
Nope, Live Expressions view does never change...
Alessandro
Ghofrane GSOURI
THX
Ghofrane
alessandro.breuza
Jan 29, 2026 9:00 AM UTC
This works.
Unfortunately, other apps I use are not happy with OS scale higher than 100%.
If there is no alternative, I'll accept this solution.
Alessandro
Visitor
Oct 31, 2026 6:01 AM UTC
The Live Expressions view doesn't seem to have a separate font-size setting. One workaround is to increase the display scaling in your OS settings.
On Windows, go to Settings → System → Display → Scale and try 125% or 150%, then restart STM32CubeIDE.
Unfortunately, this will affect other applications too.
Oct 31, 2026 11:02 AM UTC
I’ve run into similar issues with settings not applying to specific views. It would be really helpful if Live Expressions had its own font size option instead of relying on the general appearance settings. Hopefully, there’s an easy way to customize it!
Nov 2, 2026 5:31 AM UTC
