Senior
Linter for CubeIDE
are there some plugins, extensions of free linters that can be used with CubeIDE?
If not, what are the best solutions?
Thank you
mƎALLEm
mƎALLEmBest answer
Hello @Ricko,
Check out these links as they may help you:
https://mcuoneclipse.com/2020/12/29/eclipse-codan-static-code-analysis-for-c-c/
https://marketplace.eclipse.org/free-tagging/linter
https://wiki.eclipse.org/images/f/f9/CodanCDTSummit2010.pdf
Or simply google C code analyzer Eclipse plugin
Hope it helps.
mƎALLEm
mƎALLEmBest answer
Hello @Ricko,
Hope it helps.
