Robert Ritchey
Senior
Linker Error After Build
I get an error message when I go to debug after doing a build but not if I go directly to DEBUG after a clean project.  When I build my project and then go to DEBUG I get the following error message:
10:36:15 **** Incremental Build of configuration Debug for project Tx2B ****
make -j32 all
make: stat: F:/Projects/Smart-Fly/IC/MCUs/STM32/STM32G0xx/Drivers/STM32G0xx_LL_Driver/Inc/stm32g0xx_ll_bus.h F:/Projects/Smart-Fly/IC/MCUs/STM32/STM32G0xx/Drivers/STM32G0xx_LL_Driver/Inc/stm32g0xx_ll_comp.h: Invalid argument
make: *** No rule to make target 'F:/Projects/Smart-Fly/IC/MCUs/STM32/STM32G0xx/Drivers/STM32G0xx_LL_Driver/Inc/stm32g0xx_ll_bus.h F:/Projects/Smart-Fly/IC/MCUs/STM32/STM32G0xx/Drivers/STM32G0xx_LL_Driver/Inc/stm32g0xx_ll_comp.h', needed by 'Sources/Units/IC-Tx2B/MCUs/STM32G030C6/Firmware/Unit/src/SysCtl.o'. Stop.
"make -j32 all" terminated with exit code 2. Build might be incomplete.
10:36:15 Build Failed. 1 errors, 0 warnings. (took 190ms)
Why do I get this and how to stop it?
Pavel A.
Pavel A.Best answer
Yes try this.
Pavel A.
In your debug configuration, is "enable auto build" checked? Disable auto build to prevent starting make .
Perhaps some antivirus does its shadow business.
Robert Ritchey
Senior
No, auto build is not enabled.  What is enabled is "Use Workspace Settings".  I went into that and the only thing check is "rebuild if necessary".  Should I check "Disable Auto Build"?
Pavel A.
Pavel A.Best answer
Yes try this.
