Issue in GDB Debugger
I am trying to build the basic LED Blink on the STM32-N6570-DK , since i have build the code and try to run with the default settings it ends up with the following problem , whats the reason and how to solve this ?
Hello @MownishBugatha
Let me thank you for posting.
I am able to debug STM32-N6570-DK using STM32CubeIDE 2.0.
I recommend that you take a look this Application Note.
It describes how to get started with projects based on STM32N6 microcontrollers in the STMicroelectronics
STM32CubeIDE integrated development environment.
I suggest also that you connect the board with STM32CubeProgrammer and erase the Memory, before launching the Debug Session.
Thanks.
Mahmoud
Thanks.
Mahmoud
still the issue has been same even following the same steps , the issue hasn't resolved ? is there any alternative to check why it has been occur and rectify the solution
I want to know please, if you are able to connect the board with STM32CubeProgrammer.
Thanks.
Mahmoud
Yes
