subramanya
Is there any way to work build analyzer using MAP file which is generated from IAR Eclipse plugins inside cubeIDE? Build analyzer is not working with MAP generated from IAR Eclipse plugins.
Markus GIRDLAND
Markus GIRDLANDBest answer
I believe you might be able to do it, from chapter 8.1 of the STM32CubeIDE User Guide:
"The STM32CubeIDE Build Analyzer feature interprets program information from the elf file in detail and presents the information in a view. If a map file, with similar name, is found in the same folder as the elf file the information from the map file is also used and even more information can be presented."
Make sure it has the correct name and is placed in the correct folder.
Markus GIRDLAND
subramanya
thanks
Pavel A.
June 13, 2022
Which IAR version? Their map file format could change.
