RCooke88
Is there a way to reset the STM32CubeIDE back to the initial setup?
Hi All,
Is there a way to reset the IDE back to factory setup? I've somehow manged to screw things up enough that it's really not workable anymore.
Thanks,
Richard
    AScha.3
    AScha.3Best answer
    if you just puzzled the windows or menus...
    try:
    >> To fix this, just remove this file inside your workspace:
    >> .metadata/.plugins/org.eclipse.e4.workbench/workbench.xmi
    >> Hope this solves the issue.
    if more complex ... delete/uninstall and install new.
    (your projects in workspace will remain / stay the same , if you start using old workspace with the new IDE . )
    AScha.3
    AScha.3Best answer
    try:
