Is the library safe to use after the year 2038?
  • August 15, 2020
  • 5 replies
  • 1384 views
I noticed that STM32CubeIDE allows you to use a 64-bit variable, I would like to know if the time.h library is already updated with a 64-bit variable.
https://en.wikipedia.org/wiki/Year_2038_problem
waclawek.jan
August 15, 2020
Thanks,
Does this mean that What comes with STM32CubeIDE 1.4.1 is already safe from the year 2038 problem?
waclawek.jan
I don't know what comes with CubeIDE, I don't use it.
August 15, 2020
You're the developer, use the libraries that meet or exceed your expectations.
Use your own tested/validated code for things which are critial.​
Not sure the RTC is rated beyond 2099​
August 17, 2020
Thanks, I'm using DS3231.
