STTwo-32
STTwo-32Best answer
Hello @sesrikanth and welcome to the ST Community :smiling_face_with_smiling_eyes:.
You can use the CubeMX integrated on the CubeIDE.
Best Regards and welcome to our World.
STTwo-32
STTwo-32
STTwo-32Best answer
STTwo-32
ManishNair
You don't need to install CubeMX separately, its in STM32Cube IDE. However if you downgrade CubeIDE to previous version, then you require CubeMX latest version to open .ioc files created with higher version of CubeIDE
Thank you @STTwo-32 , and @ManishNair for a quick reply.
unsigned_char_array
Lead III
I prefer the standalone version. I'd like to keep my tools separate. I have two screens and this way I can have STM32CubeMX on one screen and STM32CubeIDE on another. It's not needed though.
"Kudo posts if you have the same problem and kudo replies if the solution works.Click ""Accept as Solution"" if a reply solved your problem. If no solution was posted please answer with your own."
Guillaume K
The STM32CubeMX integrated in STM32CubeIDE generates project files for STM32CubeIDE only.
The stand-alone STM32CubeMX can create project files for other IDEs: IAR EWARM, Keil MDK-ARM...
unsigned_char_array
Lead III
And it can generate cmake files.
