SGrig.1
Install STM32CubeIDE on Raspberry PI
is it possible to install this development environment on Raspberry PI
SGrig.1
SGrig.1Author
or maybe there is a utility for downloading firmware from Raspberry PI to STM 32
berendi
Principal
April 9, 2020
No.
At least not without some serious tinkering.
While most of it (including Eclipse) is written in Java, there are some components, e.g. the compiler itself, which are compiled to run on an Intel/AMD system.
Standalone CubeMX and CubeProgrammer might work though.
MPara.1
August 6, 2020
You can use st-flash ((sudo) apt-get install stlink-tools). There is also a gui alternative ((sudo) apt-get install stlink-gui). stlink-gui also install stlink-tools.
If you need a development tool chain, you can try binutils-arm-none-eabi. ((sudo apt-get install binutils-arm-none-eabi).
Best Regards.
