VK.17
IDE hangs (freezes) after collapsing ( minimizing window) and expanding (maximizing). Linux
IDE hangs after collapsing ( minimizing window) and expanding (maximizing). Or after Alt + Tab. From time to time.
"File -> Restart" only helps.
I don't know how to fix this. Please, help.
Tried to reinstall - the same situation.
IDE uses internal Java: java.version=17.0.11
As system Java versions, I have v.18, 21, 22  (checked via "update-alternatives --config java" command)
Just have an idea to try to switch from internal to system version of Java, but did not find how it can be done.
My config:
Laptop Dell Vostro 3520
Ubuntu 22.04.4
    VK.17
    VK.17Author
    Maybe this will help (see attachment)
    Hello @VK.17
    Have you tried the CubeIDE 1.16.1 version? Can you check if the behavior still occurred?
    KR,
    Souhaib
    To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
    VK.17
    VK.17Author
    Yes, the same behavior.
    Explorer
    I'm using the version 2.0.0 and the same behavior. The problem persists.
    Arch Linux, fully updated, using Wayland.
