feng_wang
I create a project with STM32CubeIDE on one computer, and need to copy it to another computer to share. I copy the whole project folder to that computer, but don't know how to open this project on that computer. What is the right procedure to do it?
Peter BENSCH
Peter BENSCHBest answer
Typically a project contains all relevant files with relative references, unless you have explicitly included header or C/CPP files outside the project folder.
After copying, you only need to import the project with
  • File > Import > Existing Projects into Workspace
Does it answer your question?
/Peter
Peter BENSCH
/Peter
feng_wang
feng_wangAuthor
Thank you Peter for taking my question.
I did try to import the project, but don't know which item on Import Wizard and which files on next import window I should take.
Attached you will see the screenshots on the project's files and import window. Can you take a look?
Pavel A.
May 31, 2023
General-> existing projects into workspace
feng_wang
feng_wangAuthor
That works. Thanks.
The step I missed is to click Restore button after importing the project. It may be a common mistake for user who used to Keil IDE.
